ITEMD2R ESO Guide - How Do I Open Crown Crates in the Elder Scrolls Online
Добавлено: 19 май 2023, 05:11
Crown Crates are item bundles obtainable from the Crown Store containing four or five collectibles and utility ESO Crown Store randomly chosen from a certain pool. Crown Crates are opened from the Crown Crate UI , which summons Pacrooti. Opening a Crate will result in Pacrooti dealing four cards, which can then be turned over to reveal your rewards. "Preview Crates" grant only three rewards.
What Happens If You Get Duplicate Items From Crown Crates In ESO?
If you obtain a duplicate item that you already own in the Crown Crates in ESO (The Elder Scrolls Online), then you will simply get rewarded with crown gems instead.
Duplicate Item Gems Amount:
132 Gems for Apex Rewards (Except Resplendent Sweetroll, which gives 400 Gems).
33 Gems for Legendary Rewards
13 Gems for Epic Rewards
5 Gems for Superior Rewards
1 Gem for Fine Rewards
1 gem for Common Rewards
To open your purchased Crown Crates, follow the process for your platform below:
PC/Mac
Navigate to the Crown Crates menu by pressing [F3].
Select the crates you wish to open and press [E].
Xbox
Navigate to the main menu by pressing [Menu].
Navigate to the Crown Crates option and press [A].
Select the crates you wish to open and press [A].
PlayStation
Navigate to the main menu by pressing [Options].
Navigate to the Crown Crates option and press [X].
Select the crates you wish to open and press [X].
Once opened, your new items will be automatically added to your inventory or collections, and any Crown Gems received will be added to your totals.
Gold is free in-game currency while Crowns cost the player real-world money. However, buying Crowns using gold does not mean a player is able to buy the Crown directly using Gold. It means that the player will be able to buy ESO Mythic Items from other players who are reliable in exchange for gold. It is also very important to choose a safe and reliable merchant to buy, I recommend you a safe ESO Crown Store https://www.itemd2r.com/eso/eso-items.html
PC/Mac
Xbox
PlayStation
